2002 CR250 Left side case seal removal
Can this be replaced without spliting the cases. If I remember correctly, you can drill a small hole into the seal, then screw a screw into it and gently remove the seal. The new one can be tapped in using the correct size socket. Has anyone done this?
storytime
Lifetime Sponsor
Yes that is correct but why go through the trouble of drilling a hole in the seal just stick a spring puller tool in the inside lip of the seal turn it 90 * then hook the seal and pull it out. You may have to do this a few times arround the seal to get it out.
