N notiller Member Dec 16, 2006 1 0 Dec 16, 2006 #1 Hi everyone iam new here so bear with me. I bought a 2002 XR 80 today and when i got it home i noticed the motor would die when you threw the trottle wide open real fast. Works fine if you do it at a normal speed. Whats wrong is the carb. Thanks
4 4thGearAndPinned Mod Ban Nov 25, 2006 259 0 Dec 16, 2006 #2 May be a lean main jet. I've seen this with a 2003 xr 100.
Ol'89r LIFETIME SPONSOR Jan 27, 2000 6,958 45 Dec 17, 2006 #3 notiller said: the motor would die when you threw the trottle wide open real fast. Works fine if you do it at a normal speed. Whats wrong is the carb. Click to expand... That is normal for a 4stroke with a standard carb. You may be able to improve it a little bit with jetting changes but for the most part it is normal.
