2003 RM85 suddenly won't shift???
emartin
About a month ago i noticed a little oil seepage from the bottom of the case.. I bought a gasket kit, piston kit and took it to my local shop.. they put it all together, we rode for about one hr and i noticed a vibration so i took it back in.. he said the flywheel nut had come loose and fixed it.. we went out the next weekend and as soon as my son got on his bike he noticed it was stuck in second gear.. i was able to shift it with my hand but only with a little force.. any ideas about what or why it would do this?? has something suddenly woreout?? thanks in advance!!
SHSPVR
200
Hmm sound he done poor job at rebuilding the motor in the frist place.
If you noticed a little oil seepage from the bottom of the case a round the tranny drain plug then that mean you most likley have a crack which is common problem with the RM80/85 very thin wall drain plug support.
As for the stuck in second gear it could be any of a number of things.
