DPR250R
8
I purchased a 2005 CRF450 used in the fall. The suspension (valving and springs) was set up for a 150 lb "B" rider by Facorty Connection.
I am a 200 lb "B" rider.
Can I get away with just changing the springs or would the valving need to be changed too?
I keep going back and forth between-
A. Sending it back to them and paying around $600 to have it set up for me
B. Putting the stock rear spring in and .49's in the front. (That is what I hear everyone is doing)
C. Putting the stock springs in and going from there.
Any opinions?
mxneagle
320
I'd give it a try with just putting the stiffer springs on it and then trying to dial it in with clicker settings. For the most part you won't see vast valving changes for a 50lb weight difference and the same level of rider from my testing so you may be able to catch it with the clickers. A large part of suspension setup is rider preference, I like my bikes on the stiff / springy side and my brother-in-law (about the same weight and speed) likes his softer and slower.
DPR250R
8
OK... you answered the EXACT question I had. Thank you... I really appreciate it!
I am not afraid to admit that I know nothing about valving.
Now my next question.....
If I go to Race Tech's site and enter my information about spring rates it says to use the stock springs basically.
I read in MXA that the hot setup is run .49's in the front and lower the oil volume.
What is your take?
I have the stock springs... but would not mind buying some new one if it is worth it....
