400ex4ever
10
I have been researching and reading several different forums which recommend running a 2008 carb on the older year motors. The 2008 uses a 40mm Keihin flat-slide while the 2007 uses a Keihin 40.0mm flat-slide with throttle position sensor (TPS). I also noticed the CDI on the 2007 has an electronic advice and the 2008 does not. On another note, I got a price quote from service Honda to get a 2007 or new CRF250R and the recommended the 2008 carb. I guess what I am asking is will the 2008 carb work with the 2007 CDI or will I need to get the 2008 CDI.
bwood
135
Not sure of the compatibility of the two carbs. Just curious, what is the purpose? Is something wrong with yours? I was thinking that the 06-08 carbs were the same, and the 04-05 are the same. Same goes for the exhaust systems. Looking at the microfische from Service Honda, all of the carbs utilize the same TPS from 04-08, part #16060-KRN-671. The only talk I ever heard on switching carbs was to run a 05 carb on the 06 bikes due to tuning issues with the increased size of the 06 (if I remember correctly they went from 37mm in 04-05 to 40mm on the 06-08 bikes). I think now this has been remedied on the newer bikes. If you are having issues with your current carb, it could just be jetting. I would try to repair/retune what you have before dropping $400 over what could possibly be a $5 jetting issue or possibly a jet kit fix.
Just jet your bike, set the ap timing, and it will probly run fine. I run a JD needle and 70 leak jet. Never bogs. Runs crisp and smooth. Likes main jet tuning for temp and humitity changes. It's a bit tempermental, but runs good when properly tuned.
400ex4ever
10
I will give everyone inputs a shot when I get it put together. Is the JD needle only one size?
I did a little more research and this is what I got off the microfiche for the 2008 and 2007 CRF250R's:
2007 Honda CRF250R Carb
CARBURETOR ASSY. (FCR01D A) 16100-KRN-A02 $538.40
2008 Honda CRF250R Carb
CARBURETOR ASSY. (FCR01E A) 16100-KRN-A12 $598.35
The part numbers are a little differnet that is why I originally asked. I would rather not spend teh extra money. I still need to pay for fuel... :ohmy: :ohmy:
I'm not sure, but I think the AP actuator has been slightly changed over the years, as well as the jetting. The carb body should be the same since 06.
400ex4ever
10
Joe,
You could be right. I did get another email for Service Honda. The 2005 CRF250R Carb is a 37mm like bwood said. I also went a head and got the JD jet kit. I noticed it comes with 4 different needles. Any suggestion on jetting, needle selection.
My JD kit only had 2 needles. Red and blue for warm and cold temps. Had about 5 main jets and 2 o-rings. The kit comes with a good guide to get it set up correctly. If you have any questions you can call and talk to them.
