As the title says...I've got a 01 RM250 with standard bore, wiseco piston, approx 10 hours on rebuild. The head had been milled, but Eric Gorr re-milled some squish back into it. I've been using 99 octane gas plus Klotz at 32:1 (BR8ES) and the bike seems to still be detonating. You can tell at idle (surges) and at very low throttle (almost none) the bike jerks around.
I finally found some higher octane fuel around here...107 and 112 (VP maybe?) I'm wondering if anyone has a suggested MINIMUM octane requirement for 235 psi and can tell me if the bike will need to be re-jetted. I've dug around here with searches and couldn't find anything conclusive on the subject.
As is, i was going to go with straight 112 octane at 32:1 with Klotz and the same plug without touching the jetting. To memory I'm running 46 pilot, 162 main, 3rd clip and like 1.5 our on a/s.
Micah
Micah
