Suspension tuners....
I have an 03 250f and have tried about 4 different base valve/mid-valve lift setups..still trying to get it right. I race harescrambles and really am trying to plushen this up on my own without blowing the stroke so easily. One more try then I'll probably go with MXT for a revalve......I've read that the stock spring .44's I believe are adequate for 180lbs...
1) anyone weighing in around 165 tried a softer rate with good results?
2) The mid valve compression has the following stock setup. Anyone know what the 16x.1 shim is for located between the piston and the 20x.4 shim? Thanks.
Piston
16x.1
20x.4
(3) 27x.1
24x.1
16x.1
(3) 14x.29
25x.4
spring
collar
(2) 11x.25
Piston
16x.1
20x.4
(3) 27x.1
24x.1
16x.1
(3) 14x.29
25x.4
spring
collar
(2) 11x.25
