crack rock
51
thinking of switching from 32:1 to 40:1 on my rm 250. is there any performance gains with 40:1? will it cause the main bearings or top end to wear quicker? also how much leaner will i have to jet it?
No
Maybe
You are unlikely to notice any difference unless you are changing to a different type of oil at the same time. Even then it's highly unlikely that you would have to change jetting due to such a small volume change in oil.
psustang89
63
I know some guys who woods ride competitively and they run 50:1. I was told that 32:1 is more for MX, high stress riding. So according to them it depends on what kind of riding you do. It makes sense that you would need less oil if you're lugging around the woods than if you're wide open on a MX track. I'm running 40:1, but my jetting isn't perfect yet...
magneto
179
I run 32:1 (Golden Sprectro) in my EG ported CR5 and it doesn't seem to be lacking power :laugh:
I always figured oil was cheaper than parts and more oil should equal less wear on all internal parts.
Seems like I read somewhere that with optimal jetting you could actually get more power with richer oil/gas ratios due to better ring/cylinder sealing... OK, I got my flame suit on fire away!
DLHamblin
268
You are correct.
crack rock
51
looks like im stickin with 32:1
why do some people run a leaner mix if there is no performance gain and more wear on the engine?
Papakeith
COTT Champ Emeritus
6,695
51
RI
because they can save .000000002 cents on oil costs. I used to run at 20:1 worked just fine for me.
sick 96 250
1,207
i've ran 40:1 for the past 10yrs at least and never had any problems. 32:1 compared to 40:1 is not much, once you start getting up to 50:1 and more thats when I would worry
