OK here's my idea!
I got this 36 mm carb from my old KTM 200. Mines a 35, (2001 KDX 200)that you can send out to get punched out to a 36.
The intake boot is too small to use the 36 on mine.
I've taken some rough measurements on the 2002's and man it looks like a 125 boot will fit, but I don't want to spend the bucks to order on in that'll end up sitting on the self.The reed block numbers for a 250 and a 125 and a 200 are different, (that's not surprising) if anyone knows someone that has a 125 or a 250 that can take a close look and maybe measurements, Man, I sure be happy.
The idea I have is that most of the Hare Scrambles I did last year I could use a lot of top end and run it like a 125. The enduro were mostly bottom and mid courses. The Mx were top end. I get a revver pipe, whip on the 36, differnet reeds while I have the boot off, boost my gearing to front to 13 and abuse the clutch and scream to first place. Next race is a low end grunt track or course, I drop my low end pipe, (I have one, a dyno port set up) my power reeds, drop the front to a 12 and grunt my way to first again! Seems like a do able thing!! Any help on this plan or ideas would surely help!!
Thanks !!
Joe
2001 KDX 200
2001 TTR 125 Boy "A"'s
1996 XR 80 Boy "B"'s
you gotta always push the envelope
Thanks !!
Joe
2001 KDX 200
