i rejetted my 01 520 mxc
ocemn needle 3rd clip
165 main
.75 turns on air screw
i also removed the crank breather tube from the carb.
the problem is that it seems to be backfiring way too much when off the throttle. normally, from a half throttle acceleration to closed throttle, it will pop 3-4 times as soon as the throttle is closed. after a high rev full throttle acceleration, its even worse. i have tried moving the needle and changing the air screw with no results. have the stock mxc exhaust w/ sa. i know its not a big deal, but if i can fix it, it will make the muffler packing last longer. my buddy rejetted his 400 and it doesn't backfire at all.
later
165 main
later
