andthereyouare
- Mar 28, 2006
- 2
- 0
Hey all, I'm new here.
I read some threads on my topic and have tried numerous ideas... Here's my problem I received a Honda 1974 z50. There is no rust at all on it. It sounds like it has good compression, but I have "No Spark". I'm not sure when it actually ran last. So I replaced every piece of electric portion on the bike, except the tail light.
All brand new:
1) Ignition Coil
2) The entire Stator ((capacitor, points and coils) Gapped the points to the manual settings)
3) Complete wire harness
4) Kill Switch
5) Dimmer Switch
6) Spark Plug (Gapped it according to Manual)
7) Headlight
I'm not sure what the spec is for the electrical current through each item but I am getting voltage. I put the spark plug on the block and crank it with no spark to be seen.
Oh and I'm not a motorcycle mechanic, so I'm learning. I'm thinking this is the same scenario as you would have on a push lawn mower with a pull start, right?
Any ideas would be awesome!
Thanks,
Jim
All brand new:
1) Ignition Coil
4) Kill Switch
5) Dimmer Switch
7) Headlight
Thanks,
Jim
