Benesesso said:I bought a "full-wave" bridge rectifier from Radio Shack for ~$3 and a small 6 volt sealed lead/acid battery. The coil will now charge the battery if the revs are up a little, while the battery helps prevent high voltages from burning out the bulbs. I am just now testing this setup, and I may find I still need a voltage regulator. If so, Radio Shack has them pretty cheap.
