Does anyone know if there is a clearance issue with the cluth side case and the kick starter's gear. Just did a complete rebuild on the bike. when i put on the case that covers the clutch the kick start lever will not come back up on it own (feels tight). If I loosen the case it works fine, tighten it back down and it rubbing something again. I had this thing apart several times today trying to figure out what its rubbing on, but can't find anything. I've looked over the book and followed all the directions, this just does not make sense. Anyone elese ran into this in the past?
Also the motor runs fine you just have to manually pull the kick start lever up with your hand after starting it. If your wondering theres nothing binding anywhere from the rebuild. With the case of this thing is super smooth and everthing spins freely. And the spring is attached properly on the kickstart.
Any suggestions?
Any suggestions?
