89 KDX200 sharp and precise carb tuning
bill kdx nj
8
Best bike ever. just got back from fredette had ports polished and its wicked fast.
Right now I have a
48 pilot
150 main
1172 needle
throttle slide #6
it mostly rips at wide open.
what can i do to clean up the rest of the throttle range?
i got fmf pipes, no lid, boyseen reeds.
would a 45 pilot give it more torqe from 1/4 to 1/2?
would a 152 main give a little more top end?
would #5 or #7 slide give more torque?
I want the bike to be really SHARP and hard hitting preciseness!
THANKS
G. Gearloose
Pigment of ur imagination
Jul 24, 2000
709
If you want sharp..I suggest a CGK needle from sudco. start in middle clip then try second from top. Use a 40 pilot with that needle, keep the #6 slide. set airscrew for best off-idle response, non of that highest-idle crap.
BR8es plug, Set the main w/ WOT chops to get 1.5-2 mm of soot on the base of the insulator of a new plug the part you can't see well. cut off the threads to see down in. Don't be ascared if you see a white insulator tip, white means its self-cleaning, like it should. Grey is bad.
