:bang: Have a problem with thick white smoke from a KDX 200 96' from 1/8 to 1/2 throttle untill I revs it and this cleans it out untill its back at idle to 1/2. This makes it very sluggish and a loss of tourque occurs in the bottom end. She has been given a complete overhaul, new piston, rings, cylinder cast iron (stock size), Boyesen dual stage reeds, new crank seals and bearings which were'nt in bad shape but still replaced. It still has white smoke prior to half throttle when the high RPMs clean it out and it runs clear. The packing will be replaced soon and the pilot jet is at #48 moving to a #45, and the main jet is moving from a #160 to #158, and the air filter is a new "Ready filter". Will my decrease in jetting solve my smoking at low RPMs? My power valve assembly has been removed cleaned and reassembled. The Top End rebuid was what I used as a refference so I believe that it is installed properly. The bike runs great wide open, but at idle once it has warmed up it seems to decrease to the point of stalling, I want to ride this thing, and I worried about possible damage, could this all be from improper timing or electrical issues. I need some input or things to try. Thankyou in advance.
