Motojunkie,
Your right on track man. That is a concern of extreme importance when you design a piston. PA did this also by raising the surfaces, leaving a larger gap between the shim and port mouths. RT accomplishes it by reducing face shim diameter. The less that flow is interupted the better.
Consider the current design of the stock KYB 28mm fork piston. That is excellent design. With smaller ports it would be the bomb in my opinion. A little work on the entry points might be nice too. But for a stock piston it is awesome.
