A question about leaving fuel in the tank...
trist007
105
I got a 2010 KX-250F. However, it's been in my garage for 2 years and I haven't started it since. Should I remove the fuel from the tank and carb or start it up?
-Tristan
Change the fuel for something fresh. If you didn't drain the float bowl before you put it away the last time, then you will likely need to pull and clean the pilot jet at a minimum on the carb.
