I`m installing a Acerbis DHH twin headlight on my 99KX250. Has anyone else installed a headlight on their KX? I want to know where you routed the front brake line. In front of the light or behind it? If behind it did you have any problems with it rubbing on things when the front forks go up and down? I`m going to change the 35 watt bulbs and install 10 watt bulbs and tap into the power jet wire to supply the 20 watts for the light. I have heard you can safely pull 25 watts from the powerjet wire, 20 for the head and 5 for a tail light.
