I assembled a gearbox today for a 1977 Yamaha DT400. The crank spun just fine after putting it into the first half. Later when I put the second half together, there was a small gap all the way around the cases. I snugged the bolts up little by little and the gap closed but it was more stubborn around the crank area.
Now, the crank will not spin. On the clutch side there is no clearance betwenn the crank and the case. (Im sure thats whats stopping the crank) On the gear side, I an get a sheet of paper between the crank and the case so that ones ok.
So has anybody had this problem before? Ive done about a dozen or so motors in th past, and never seen this before.The crank is not from this motor, but from the same year and model bike. The mains were not changed so I dont think there is a problem with them being seated or not...
Its almost like the crank is too wide for the cases but I cant imagine why that would be....
Any ideas would be appreciated.
Thanks,
Neil
ps....I took the bolts loose and the "gap" around the crank area showed up again on it's own, and of course the crank spins nicely now, but jeez theres a 1/8 inch space there...Im gona split the cases again and take the crank out and I guess Ill start by measuring it against the bad crank I took out of there....AGGGHHH! :ugg:
Thanks,
Neil
