Does anyone know if I can get an aftermarket piston for my 83 KDX200? I have tried the weisco site and they only had one for a 86 and up. Could I use the same one since the bore is the same? Is the stroke also the same? :worship:
It all depends on the size that you had before. If your cylinder walls are good then stick with the same size. Just get a hold of a micrometre, you could buy a cheap one but what i'd do is go to your local dealer and they should be able to measure it for you at no cost. Then call wiseco give them the measurements and your on your way
