DougMXer
91
Air Box Sealing on 01 YZ250
I have disassembled the air box on my 01YZ250 and am wondering what sealers I should use where.
Trying to explain the design is difficult. The air boot, fits into the air box, there is a foam liner on the edge of the air boot, and then the plastic air filter seat with studs coming out of if that fits over the foam sealer. And also there is an aluminium ring on the outside of the air box
What I want to know is where do I use weather strip adhesive, do I need to glue the foam liner onto the air boot? If so with what and any other places that need to be sealed to ensure that the entire intake system is sealed.
Cheers Doug:)
NO HAND
1,198
Weather strip adhesive goes on each side of the foam. This is between the rubber air boot and the plastic filter seat. Be very careful not to over tighten the bolts because it could warp and cause a leak. It happened to a few people so far.
