Hi,
I just purchased a pair of T8's and had a couple of ?'s. I was previously riding a cheap pair of Fox Trackers which had far less rise over the toe. This extra inch in the new T8's is causing some problems. I'm having problems getting under the shifter cleanly and am worried about missing up shifts. I currently have the shift lever set with the bottom of the shifter even with the top of the foot peg, which I believe is the correct set up. I considered moving it up a couple notchs on the shaft, but am worried if it's up any higher I might end up bumping it down/out of gear coming down from jumps.
Anyone out there run into this issue when changing to a thicker toe'd boot? Thanks in advance for your help. Keep on roostin!!!!!!!!
