Is it normal for the bike to jerk forward a little bit when you shift into first gear? My '97 YZ 125 does this and sometimes it stalls out on me if I don't give it any gas while shifting into first gear... It also makes a "clack" sound when I shift into first. I also noticed that when I do shift into first gear, the idle speed changes (idles lower then when in neutral). I just changed my tranny fluid and I was hoping maybe that would help, but it still does the same thing.
Is this normal? If not, what needs to be done to fix this? I can't possibly see how this can be normal... if you're holding in the clutch and you shift into any gear, it should not jerk whatsoever.... maybe I'm wrong.
Help!
Help!
