gearren
20
I have a 2000 yz 250 and the last two times I have changed my oil, which I do after every two rides, the oil is thin and has a greenish tint from the antifreeze more than likely. Where can the leak be coming from? It cant be the water pump oil seel because no antifreeze is coming out the weep hole which tells you when the seel is bad? So where should I be looking?
CRazy250
334
check water pump shaft seal and bearings,i had the same problem on my 82 rm125 and it was so bad it leaked frothy creamy white stuff
trial_07
Play with gravity
1,430
Is the level of antifreeze in your radiator dropping? If not, it may not be the problem. Antifreeze in your oil should make it white, not greenish.
trial_07
Play with gravity
1,430
Aren't the waterpump seals the only option? You may not be seeing it. I'd try new seals.
