I'm changing the piston/rings for my first time in my 99 CR250, have take the cylinder off and just am about to start taking the piston off but just have a few questions.
Should I clean the cylinder out with anything? It looks pretty clean and smooth in there. My piston is in good shape, the only reason I'm in there is because my powervalve was stuck open and figured I may as well put the new one in. My old one had about 15 hours on it.
Does anyone have any tips for doing the power valve? I am most worried about lining it up when I put the cylinder back on. How do I know if its lined up properly?
Should I put anything on the gaskets or just do them dry? Any tips to remove the old gasket residue?
I didnt remove the cylinder head but should I just to put a new head gasket in as it came with my gasket kit?
As you can tell im pretty new to this so any other tips would be appreciated.
