I purchase an upper and lower clamp set from Motosports. The first set had two stripped bolt holes. I sent them back and it took a month and a half to receive a replacement. Now the second set is defective too. Every time I ride I have to tighten the sterring nut, loosen the top clamp, then tighten the top clamp nut. I thought it was just the new bearings and races seating. But I have tightened it almost an 1/8 of an inch.
It appears as thought the steering stem is being pulled through the lower clamp. Has anyone had a similar problem?
Thanks, Steve.
Thanks, Steve.
