Anyone replaced bar mounts on 06 YZ250?
J.B.426
235
To go to pro taper bars I was going to get the oem oversize bar mounts off a YZ250F or 450F, since they come with pro tapers, but they are on backorder until Dec. 30. Does anyone know if the oversize bar mount kit that pro taper sells would bolt up to the stock 06 YZ250 triple clamp? That seems to be the best priced bar mounts I can find right now, but I know they advertise it for the rubber mounted bar mounts on the Hondas and Kawasakis. Or does anyone have any other suggestions? Thanks.
Dec 1, 2005
For my 06, I used the bar clamps that are sold with cheaper pro taper triple clamps. I think you can buy just just the bar clamps too. But because the pro taper bar clamps were surpose to be on a thinner mounting surface, the bolts on the were not long enough. A fast trip to home depot too care of that, $1.60 cents for two bolts and I was in business.
I got some pics if your interested let me know and i can email them too you.
J.B.426
235
Thanks a lot, I got the pics. So those mounts have the bolt that threads into it from the bottom? Other than that they look about the same as the oversize bar mount kit that pro taper sells for $39.95 retail. I emailed pro taper and asked if this kit would work with the 06 YZs and they said they had not tested it yet but that it should work "if there is enough metal on the top tripple clamp to take up the space so the threads can get a good bite". So I am now thinking they will work.
Dec 1, 2005
Yes what they said ... ""if there is enough metal on the top tripple clamp to take up the space so the threads can get a good bite". "
Well there is not... because the bolts they provide that goes through your triple clmap and into the bar clamps is not long enough... Thats why I had to go to the home depot and round up some longer ones. Its worth it though, because the stock YZ bars sucks so bad... even the bend is really bad.
J.B.426
235
Thanks, I'll probably just wait for the oem ones off the F bikes and everything will match up nice and pretty. :)
