CanadianRidr
- Oct 22, 2001
- 2,018
- 0
- Thread starter
- #51
First Update
Ok so the rust wasn' that bad actually, After sanding it off with some 80 then I jumped right to the 220 it worked pretty good, I got it right down to the metal to make sure it won't come back, so there was about 6 spots that ended up being slightly lower than the paint, but not needing bondo *thank god :)
So I just made the edges of the paint smooth with the metal and the whole roof felt fairly flat and smooth, I went over the whole roof several times with the 220, and have just put the second coat of primer on the bare spots, and already everything seems nice flat and level, I think I will sand the whole roof once everything is dry with the 220 dry, then go to bed,
When I get up I will wet sand the roof with the 400, then start spraying :)
I have pics so when I get them up, you will all see them.
