overthebars
- Jul 9, 2005
- 8
- 0
I just got done putting my 200 RM125 back together from splitting the case to replace some tranny gears. Things went fine till I tried to start it. Now... the dang thing has no spark! I went through the trouble shooting routine. New plug (still no spark), check kill switch ('twas OK), check the stator (OOPS!). On the stator check-out, it asks to check the resistance between the red/black and red/white wires (the ones that lead to the windings). It supposed to read 18 to 28 ohms. Mine reads infinity ohms. That sounds like a broken wire somewhere, and assume this is my problem. The connection terminal and wiring to the windings look fine. Everything around the windings is covered with epoxy, so you can't see anything if anything is wrong down at the stator. The unit was not dropped or mishandled during the overhaul.
Is this a normal thing to happen? I have never heard of a stator failing like this before. Is there something more to check or try? Do I have any choice other than buying a new one? (They are REALLY spendy!) Can they be re-wound? If so, by whom?
Willy T
Willy T
