Aaronkdx
25
My engine on my 2000 kdx200 is making a banging noise. I does not get louder when it revs. It actualy kinda goes away. I changed the gear oil and put 700cc in it. It still made that noise. I just bought it last week ago. It's in real good shape. just a few scratches. I took the spark plug out and it was a little brown right at the tip. I guess thats good. I have the stock pipe & silencers on it and the air box lid off. Please help me out here.
Rhodester
549
"Banging" is a little vague. KDXs make lots of crankcase noise. You might try dumping the rest of the quart of oil into the crankcase and see if that reduces the noise. Many of us do this with good results. If that doesn't help try giving a little more in depth description of the noise.
Aaronkdx
25
I can't really desribe it, it's almost as loud as the engine & exhaust(stock pipe&silencer) but it goes away when you rev it alittle. I am taking to my local shop to have them look at it tommorow? Does any one else have this problem. This kid that lives out the road and has a rm85L say his dad's 04 rm250 does the same thing. His dad says it's PISTON SLAP. He also said that those 200 Kawasaki do that.
css_elfers
166
My brothers 98 200 does the same thing. We've done all that you have said you've done with no improvement. Let us know what the result from the shop is.
Thxs
Elf
Rhodester
549
Although the normal KDX crankcase noise is pretty loud it's not piston slap. If you've heard piston slap you'd know if that's what it's doing. Piston slap is what you get when your piston is worn out and the clearance between the piston and cylinder wall is too great. It's cure is to replace the piston. I have a KDX200H with an FMF-30 pipe, An FRP pipe guard, and an FMF Q silencer. My crankcase noise at idle is greater than the exhaust noise even with a full quart of 10-40 or 20-50w oil in the engine (the manual calls for 10-40).
ellandoh
dismount art student
2,958
cr deathrattle sound familiar ........the honda clearances are way off i put a B piston in my A cylinder and whallaa :cool: death rattle mystery solved :bang: too bad i didnt join before the dozens of speculating threads i poured over looking before i got a chance for a top end
Aaronkdx
25
OK so I got the top end off the bike and am taking the sylinder to a shop. The guy listened to the bike and said that it is louder than it should be, so got home and started taking stuff apart. The bearing that the connecting rod goes to in the bottom end has alittle bit of play :bang: It has side to side but thats normal. Up and down is bad :| So I will post later when I find out more
Aaronkdx
25
The bearing that the connecting rod goes to in the bottom end has alittle bit of play up and down!! Great, now we are talking big buck, split cases, new bearing, assembley fee, etc.
ellandoh
2,958
give it a go yourself first , worst could happen is you pay to assemble only instead of all
heck i saw a thread a couple months ago a guy offered beers and dinnner to any DRN'er in his area who'd oversee his project and the guy got multiple responses and some more riding partners :)
Aaronkdx
25
Well I took the bike to the shop and let them look at the conecting rod with the play, and they said that its fine. It just must have been my inagination. Well the pistion was a little worn, so I just ordered a new top end. He said he coundn't find what was wrong with it. So I will see if it makes that noise after the new top end and breaking it in. The cylinder is good.
razrbakcrzy
136
you have the KDX rattle. I venture to say that it is the same as all other kdx's. They all rattle during idle. It's a fact. What happens is you get use to hearing a bike that does not do this and it makes the KDX's sound like they are going to blow up. Just calm down and ride.
Jim
StrokesX2
44
I had the same reaction when I first rode the KDX. It sounds like the top end is going to self distruct. Much different from other 2 strokes I've riden.
Benesesso
30
Glad I found this forum. I recently bought a nice 1986 KDX200 for $700 USD. Only thing missing was the stock muffler insert (baffle pipe). But when the seller fired it up and I heard that engine noise, I figured I'd have to do a top end job. Seller said "It always makes that sound"--guess he was right.
So after checking it all over after I got it home, I greased the fittings, oiled the chain, changed the trans. oil, and went for a ride. Runs fine below about 1/3 throttle, but simply will not fire above that. It just goes way lean, not rich. Returned home thinking the main jet had to be plugged. Pulled the float bowl and the jet was clean-as was the rest of the carb. The float level wasn't low at all. I looked at the jet under a low-power microscope and it appears to be a 320--the carb. is a Mikuni, not a Keihin.
Any ideas on why it goes too lean to fire? As soon as I return the throttle below ~1/3 it runs fine!l
Rhodester
549
Benesesso, If it's lean it will cut out on you. If it's rich it'll "4-stroke" on you (acts like it resists gaining RPMs, just kind of "misses"). If it is indeed lean I'd check for a fuel starving problem (tank petcock or pickup tube, dirty needle and seat assembly, low float level). You can test your lean theory by adding some choke when you're in the problem area and see if the situation gets better or worse.
Benesesso
30
Rhodester,
Thanks for the quick reply. The problem isn't "fuel starvation" in the usual sense-the engine just quits firing instantly any time the throttle is opened more than ~1/3. It doesn't load up (rich)-it immediately runs fine as soon as I back off the throttle. It also happens at any RPM-low, mid and high.
I'm starting to think the KIPS is to blame--gotta read up on how it works.
Benesesso
30
Rhodester,
OK, I'll try the choke tomorrow. I also regapped the plug down to .018" from .025". I'm now thinking that the ignition may be dying and simply can't fire a .025" gap under high cyl. pressure. This makes sense to me because the failure to fire is just as if I were flipping a switch--it's so abrupt both failing to fire and then running fine as the throttle is backed off--no blubberling, etc. at all.
nickyd
873
anybody know exactly where the "KDX rattle" from? is it the Pvalve fluttering? I've often wondered that. makes it harder to tell when she's worn. Just did my top end today - started it up and she rattled like a dream!!!
Benesesso
30
Thread resurection time. My engine cut-out problem was the spark plug gap. Regapping it to .018" solved the problem.
New problem--where does the rubber tube (breather tube-?) go that's located on the engine just below the carb? Is it just a drain hose? I pulled the carb off a while ago and can't remember where it goes.
Bike is an air-cooled 1986 KDX200.
IndyMX
Crash Test Dummy
5,548
Amo, IN
That's a crank case breather, route it under the swing arm with the rest of the breather hoses from the carb.
Benesesso
30
Thanks, Indy
Got the bike back together. Been about a year since I last rode it. Was a bit lean on the low end, so I replaced the stock #20 pilot with a 22.5. We'll see how it works.
