Tonight I started installing Maier deluxe wood pro handguards and ran into a couple snafu's.
1 - The left grip a bear to get off since the whole length is glued. I cut it but there is a tough layer still on the bar, any easy way to get it off?
2 - I plan on cutting off an inch on either side since I ride tight woods trails. On the interior end of each bar is a tack welded inner tube. Will that fall out when I cut 1" off each end?
3 - Do I need to cut the plastic end off the plastic throttle tube to fit the guard?
3 - After getting 1-3 done, it actually looks kinda iffy whether the everthing will line up and fit correctly, anyone else use the Maier's?
