03cr125r
Spammer
Dec 29, 2008
15
so i have a 03 cr125r and i got the wheel off and put new sprocket and disk on it and want to put new bearings and seals in it. I got the 2 bearings on the sprocket side out but on the brake disk side there is a bearing retainer and only one bearing. I cant figure out out to get the retainer out. it says to take it out and it says to do something with a drill in the service manual but doesnt go into any detail. does anyone know how to get this out.
IndyMX
Crash Test Dummy
5,548
Amo, IN
There is a tool you can buy to take it out, or if you have a new retainer to replace it with, you can use a brass drift and a hammer and turn it out.
mideastrider
827
There should be about 4 peen marks (dimpled marks)that are used to stake the nut so it can't come loose. Drill the peen marks just enough to relieve them where the nut can be removed.
03cr125r
Spammer
Dec 29, 2008
15
how do i drill it like right on the center of it or what.
