BIRDDOG
16
I performed the bk mod to my 2000 yz426f.It seems fine , giving it gas when idling , but when i ride it, it stalls alot in throttle on off on situations. What main jet has anyone tried and worked out well.
I only raised the needle 1 clip, the fuel spray is set around .50 sec,
and the fuel does not hit the slide when the throttle is applied.
I did not change the main. What size should i go to?
wayneo426
810
Sandbar, NY
Bird Dog,
Im running a 168 Main / ELN needle w/ the BK down here on Long Island.
Shaw520
1,082
6
Eunos, The BK mod is an alteration to the accellerator pump arm, located on the carb. More throttle response can be found by shortening the squirt duration. Do a search on BK mod and you will find much info.
wayneo426
810
Sandbar, NY
Best BK info
here is the most detailed advice you can find on the BK mod. Garrett went thru alot to post this stuff, and its all good.
BK MOD
