Ed H
I have a 99 KDX 200 made into a 220 with wiseco piston kit,also a full pro circuit exhaust with a add on spark arrestor, boysen reeds and hot rods rod kit.There seams to be alot of black smoke coming from the exhaust.Is this normal? I also ride at 8,000 ft in altitude. I did purchage the bike that was being driving at 4,000 ft. Is this something I can fix with re-jetting the carb or with fuel mixture?
DirTasteGood
37
What is your Premix ratio. I mostly run 32/1 with klotz. I mix more oil if i know i am going to be running it long and hard. Is there any thing in the fuel?
mudpack
637
You have a two-stroke motorcycle.
Two-strokes smoke (dark..usually blue).
It is normal.
Nothing wrong with your bike.
Probably.
mathd
208
higher altitude mean less air density.
so it need a little less fuel.
But, it is also normal for a 2 stroke to smoke a little.
it is better more thant not enough.
Ed H
I have been running 50/1 but most of my rides are long and hard
I'm runnin' 100:1 and can't figure out why my plugs keep fouling and my crank bearings blow apart?
