I was recentlt riding my bike and lost all compression, When i took the motor apart I found out that there was no coolant in it. What problems could i be facing?
Check the rad cap-look on the rubber seal for anything that will stop it sealing on the rad.Check the water pump-look at the hole underneath the case-it might be dripping from there-new seal/bearings and pump shaft needed if it leaks.Look at the head gasket for signs of water going past into the combustion chamber-good luck.
Anyone have any ideas on how to make my bike any faster? It is already punched .50 over and the head had .010 saved off it, Porting is coming this winter as is a pipe. I hope a bigger carb (only have 36mm) if i can find one. The bike is a 1985 Cr250.
