motofreak2007
- Jun 28, 2007
- 6
- 0
ok a couple problems i have with my bike its a 1990 rm 250 and the rear brake doesnt work and it is very hard to kick.
first the brake-- i thought it was the brake line so i put a new one bled it and didnt work. than i tightened down the bolt that made the foot brake push in the plunger more and the brake seemed to work it push the pads in and there was pressure but it would still go all the way to the floor sometimes and have no pressure. ok one thing is im missing the spring that goes from the lever to the frame. but i dont think thats the problem i got on the bike and started it which took like ten minutes. but anyways it would brake sometimes and lock up and skid so that was good but at certain points it would just go to the floor and no brake and i would have to bring the lever up by foot b/c of no spring but anyways i think the problem is that the rotor is warped,(not completely flat). the reason why i think this is b/c i had this problem once before, my mom was putting her harley for sale on the sidewalk so she put a disc lock on the rotor, and she forgot went to start it and the rotor hit the caliper or forks but anyways she dropped it and it warped the rotor and the front brake worked the same like my dirt bike it would work at some point and than when it got to a point the lever would just pull but no pressure and no brake so after we got a rotor it worked fine again. so if you think that it sounds like a need a new rotor please tell me.
ok second problem-- when i kick the bike there is barely any kick when i do kick it down when it goes back up it clicks only 4 times and the 4th is really hard to get i have to play with it. i think the crank teeth are stripped or something so please let me know what you think about it. or if it has happened to you what needs to be fixed with it. so if you have made it this far thank you very much and help is greatly appreciated it really sucks riding a bike with no back brake and i hate starting the bike with a passion and also my bike goes through spark plugs like every two to three times i ride it and when i take the plug out it is black and has oil on it so what needs to be adjusted with that? again thank you very much. and thanks for your time.
