I noticed last week when riding that whenever you shifted down it (94 DR350) would act like it was in neutral. I have heard of serval people with this problem (on DR's). The bolt that is broken is a special order part and takes a week or so to get so I ordered one along time ago knowing that when I took my clutch off I would replace it.
I just took it apart and the bolt was loose enought to turn with my fingers. I took the clutch off and unscrewed with my fingers thinking that I would just replace the bolt (as I already had it in my garge). It was worse than I thought, the bolt is broken. The end of the bolt is left down inside my shift drum.
Not sure what is needed to get it out. I was thinking of going with the lefthanded drill. The Drum is still in the cases. I would need to split them to get it out. I would like to do it with them in there.
Any suggestions for getting this broken bit out without getting metal savings all over everything and not messing up the treads on the inside of the drum?
Also, The new bolt has a yellow sustance on the threads with I assume is some kind of thread lock. Not sure if the old one has it on it or not (I assume it does)? Is yellow lock perminate? Not sure If I should apply heat or not. Sure would not want to warp anything.
For your viewing pleasure.
The red arrow points to the broken end of the bolt.
