Broken spark plug wire on 1995 KDX
David Trustrum
1,396
Where?, right at the coil or half way & if so how? It can be repaired as it is a simple stranded copper wire, but not that easy, there used to be extenders on the auto market.
You might use a sparkplug cap with a long wind in point & cut it & gut it but you need the threaded brass bit to attach the 2 pieces securely (tape over the outside just wouldn’t cut it for insulation).
