xr400forever
- Jan 6, 2002
- 51
- 0
based on all your glowing recommendations I bought a 2000 KDX 220 this week. I had a bit of a chance to look it over more carefully tonight and have a few questions:
1. The What should I do about stripped nuts for the 2 bolts that hold the seat on.
2. How often should i clean the KIPS valve.
3. The the airbox area between the air filter and carb has dirt and dust in it. How can I know if dirt has entered the engine and damaged it? Would dust likely damage the special cylinder coating or is it more likely to just wear out rings?
4. If I have the head off to clean the kips valve should I change the rings just to be thorough?
5. The rear shock seal is leaking fluid. Is this an doable fix for a basic home mechanic.
6. It seems to run weak (rich)between 1/4 and 3/4 throttle> I know I will have to check the jetting, which I am almost certain is stock. It is a Canadian model. Anyone know what jetting is stock on these bikes (to compare with the reccomendation on the justkdx site. Just wondering if anyone else has had the same problem with a new 2000 model and what the fix was. Right now temp is 17degrees and my altitude is 2500 feet.Humidity is 80%.
Thanks in advance for your help!!!!
