C Cycle Suspension "Ultra Adjuster"
JTT
1,407
I'm no guru, but I am sceptical...The decription is not very detailed about how you adjust HSC. You can see the LSC bleed hole, but I cannot see how the HSC adjustment works. Humm? for $200+ bucks? That would pay for a revalve that we know work.
I am curious if anyone here has seen this think first hand and how it supposedly works.
Their claims are a little strong. I cannot imagine it living up to those claims, even if it is for real. Sounds a little like snake oil to me, but who know? :think
marcusgunby
6,450
from what ive learnt of high speed shock adjusters-some are good and some arnt,so i would need to know that they are a good sound design to lay out that much dosh.I dont see any works bikes with them.IMO you cant make up for bad valving with external adjusters and if the valving is good you dont need alot of adjustments.
KawieKX125
946
I've ridden a lot of ccycle suspended bike shere east. Their stuff is good, but not great. They have an awesome customer service plan though.
The ultra adjuster is about as effective as my stock hi-lo adjuster on my shock. Not very effective. I would get a revalve for the best bang for your buck.
Bud-Man
139
The fork adjuster operates like the high speed adjuster on the recent KYB/Showa shocks. If you look closely, you will see a square drive on the bottom of the adjuster that will preload a spring which acts on the bottom of the valve stack. In the softest setting, it doesn't touch the shim stack at all, but as you wind it in (stiffer), it eventually touches the stack and effectively changes the diameter of the clamping shim (to a point). The lowspeed adjuster works like a traditional adjuster in that it closes off the bleed hole as it's turned in.
As delivered, the fork adjuster requires the stock piston, check plate, etc.. You can use the stock valve stack, but they recommend a re-vavle as the valve stack build is critical to performance. The main feature of the device is that it allows you to add some highspeed valving without taking the fork apart, not that it provides the best ride quality. That would come from the re-valving part. One thing just occured to me....this could be a problem with multi-stage valvestacks. As you add high speed adjustment to the fork, it will push on the "highspeed" stack, possibly closing the cross over between the stacks. Regardless, I think this has a lot more potential than the Delta Valve from R.T. (which doesn't even utilize a piston & valve stack).
I haven't worked with the shock adjuster but it appears to work like the recent KYB and Showa high speed adjusters. The picture I saw had basically the same components to it, but there could be small differences in the design.
