chevy383cid
- Aug 26, 2005
- 307
- 0
James,I have just finished installing one of your jetting kits on my 02 kx 250(nice kit by the way) I used the blue needle with the clip in the middle position, the 168 main,and the 45 pilot(wich is the same as the one that was already installed)mixture screw out 1.5 to 2.0 turns. With the motor warmed up it does run a little better and throttle response seams to be very crisp,but at idle it sounds like it is about to run out of fuel( long duration pops not the short ones that I'm used to hearing) I was just wondering if this is normal or should i swap out to the red needle or a larger main? I.m running 114 race at 32:1 maxim super M> my elevation is 1980. Thanks
