I just bought my first dirtbike, a 2005 Honda CRF250R.
Since It was used, I wanted to do some fluid changes, etc. before my first time out. I changed the oil last night (which was easy), but my questions is the following: How accurate do you need to be with the amount when refilling the motor? The owners manual said .73 quarts, and I think I put in .75. I didnt have a device to measure ounces. Is that going to make a big difference or cause any damage?
My other question was about Air Cleaners. I've been told that you need to change these pretty much every ride to 2 rides. Is that accurate? (bear in mind I am a beginner, not racer). Also, I wanted to get your opinion on brands. I've looked at Uni-Filter, Ready Filter, and No-Toil. Are the pre-oiled/disposable filters a good buy? Or do you recomend the clean and re-use type? You can score multipacks (of the Ready Filters) on e_bay for pretty cheap. Would you stay away from any of the brands mentioned above?
Thanks so much for your help, this place is awesome.
Darby :)
Darby :)
