That doesn't always work. If the carb's float bowl is already full of fuel, the seafoam will not travel down the fuel line and into the float bowl.Acblind said:by putting it in your tank and leaving the reserve open, you allow the seafoam to get into the carb and clean most of the varnish and dirt.
That is some very good advice. I have a quality screwdriver that I ground the sides down so that it is just wide enough to fit in that pilot (aka idle) jet's "tunnel". Its real easy to bugger the brass jet slot if the screwdriver isn't a near-perfect fit, for both the jet's slot and the hole the jet is located in.sr5bidder said:make sure you have a good quality small flathead screwdriver to fit into the 3/16th hole for the idle jet you want it to be nearly as wide as the idle jet or you may mess it up
Ah-ha. In that case, if you just add a can of seafoam to the empty tank, your directions would be right on. :nod:sr5bidder said:I assume the tank is empty and the bowl has long been dryed up from the way it was discribed.
