Stock sprockets 13/47 use a 108 link chain.
I run 13/50 most of the time which uses 110 links
When I run 13/49 I use a 110 link chain but it's pretty close to the end of adjustment, #8.5 I think.
I put a 110 on my 13/47 setup on my 92.... it's perfect! I believe that's what buykawasaki.com calls for. Adding two teeth should require 1 or 2 more links.
