piperpilot12
- Dec 20, 2002
- 6
- 0
I have a CR 250 mainly used for trail riding and occasional motoX track. While looking through here I've learned that I haven't been taking care of the chain as well as I should. Still need a few answers.
1) Should I clean the chain after I go riding every time?
2) If I lube the chain before I go riding, does the chain need to be lubed again thoughout the day, or am I just pushing dirt into the wear areas?
3) When I lube the chain should I be spraying all parts of the chain(rollers and side plates inside/outside)?
4) When I clean the chain I take the chain off the bike by removing the master link and soaking the chain in kerosine. Is it ok to keep using the master link after remove/replace many times over. I'm wondering if the clip will lose some of its stregnth.
