tonight i went to adjust the tension in my chain and because im an idiot i can figure it out. i actually never did it myself before. what i did was i put the bike up on the stand, loosened the axle nut, then played around with the adjusters until i had the chain at the correct tension. but i noticed there are little notches in the swingarm that you line up with the metal block with notches in it that the axle goes through, should they be the same on both sides? i couldnt get them to be on the same mark on both sides should the be? but i would set the tension then tighen up the axle nut and take the bike off the stand and the chain would be way to tight so i kept messing around with it and i still can get it right, its always too tight. can someone go through the process with me, im sure im doing something wrong.
