09oneL
959
I thought I would start another thread and see where it ends up.
I think "O - ring" chains suck. I usually replace it when I get a new scooter with a real good non o-ring chain. This year I have left the stock one on my new 300 xc and I am about to replace it - I think.
The o-ring chain offers nothing to me but, power robbing and difficult to clean.
I like normal chains and if you get a good one (D.I.D. gold) and take good care of it, it will last along time.
I use the Bell Ray lube - the white stuff
What say you clowns?
Yam7M
1,416
25
I say that I use o-ring chains (Tsubaki Gold)....and the chick in the "lose weight" add under your post should be in a different bathing suit :whoa:
There's 2 pennies from this short clown.
E_Langen
149
The ad I see is for KLR650 accessories. That must be because of the web sites I spend the most time on.
katoom125
355
I've also had pretty good luck with a "quality" non-o ring chain (at least on my 125's where every bit of power can't be wasted when you weigh as much as I do) - with the bigger bores I typically go with one of the newer x-ring chains, been pretty pleased with those.
Fred T
5,272
I'll chime in later when this thread takes off in a direction that has nothing to do with chains....shouldn't take long.
09oneL
959
:cool:
Thanks Fred, I always appreciate your support.
Have you tried the green spring yet?
Fred T
5,272
NO, I have not rode the 2-5-0 in a while. I like it so much the way it is I don't want to change it. But some day when I got some time to mess with it I will.
Fred T
5,272
tdunn976 said:
Your supposed to lube them?
NO the springs don't need to be lubed Tom.
Fred T
5,272
TCTrailrider said:
I like the Red spring. If I get stuck in the dryer and can no longer touch the ground I'll give Green a go. :laugh:
Do you think my mom left me in the dryer when I was little?? :think: Hmmmmmmm....that might explain it.
Wolverine423
2,498
Dryer no - Falling out of a shopping cart yes! That must of felt like a 2 story drop to you short nutz, which explains the severe mental trauma you display :)
Yam7M
1,416
25
Don't you mean younger Fred? Pretty sure neither one of us has gotten bigger since we were "little". :) Except for a belly roll and an extra chin, that is.... :laugh:
Fred T
5,272
Traction! Also helps the suspension work better.
Fred T
5,272
Hmmmmm....your mom musta not buckled you in the car and bounced your head off the windshield a few times at stop lights then to explain your behavior. :yikes:
ellandoh
dismount art student
2,958
what ever happened to that TASTY old leaded paint we had back in the good old days??
Wolverine423
2,498
tdunn976 said:
Was good stuff wasn't it. Damn near makes me cry thinking about it.
Ya and lead paint explains your behavior :cool:
Glad we have one another figured out here.
E_Langen
149
ws6transam
309
So classic. Note that she's running a very clean, OEM O-ring chain. Looks like Chainwax for a chain lube, as well. Regular spray-on chain lube would probably spoil the pink tutu.
09oneL
959
I would like to team with her. She and I would use KY - lots of it ;)
I am sick!
FRESH VIDEO
