I'm playing with a Stihl 032 my father in law has been fighting with for a while now. It quit running one day on him so he figured it was due for a carb rebuild and new filters. Se he had me rebuild the carb for him, which seemed reasonably clean. He put it back on and still no go. It doesn't get fuel. If you prime the cylinder with a little fuel it will fire. It has a diaphragm carb. There is a hose running from the crankcase to the carb mount. Do any of you guys know if that's supposed to pressurize the tank to feed fuel or should the carb pull it in itself? The filter and line are new/clean. I guess I'll pull the carb back off and make sure it's all clean in the meantime......
