I just adjusted my clutch play using the screw by the lever and also the screw at the bottom of the cable. (went by manual). everything seems fine but when the bike is not running it will not roll when it is in gear with the clutch pulled in. I've heard this is typical when the bike is cold, but I don't remember it being that way before. Any suggestions or is this normal? Also, how do you determine the right setting for the adjustment at the bottom of the cable?
