mikeyz
20
Took off my clutch cover to get a look at my basket to check for notches. Can the notches be seen while the clutch is intact? Or does it have to be disembled to see any wear? Also I know that friction plates wear down. Is there anyway of checking wear without tearing it apart?
mikeyz
20
Look closely and I could see some notching you can only see it if you look at an angle with a flash light. looking staight down at the clutch the basket looks fine.
rpm12505
190
Outer basket looks great,possibly aftermarket :cool:
Now for the inner. That where we have trouble. Stock inners are soft but cheap
IndyMX
Crash Test Dummy
5,548
Amo, IN
Yeah, I agree, that basket looks fine.. It's got a little bit of notch, but not enough that you should notice much of a problem.
Pull those clutch discs and measure them, and have a look at the inner hub, see if it's notched.
mikeyz
20
Clutch would not be smooth upon releasing in first gear, and I can feel like a vibration coming from the engine when I slip it to get going. Its really jerky.
Heres another
